Noise from 2410
/ Noise from 2410 #1
sandalwood
New Brunswick, Canada
L5460 Kubota
I was using my 2410 HSDB yesterday doing light loader work and my neighbor who was helping me mentioned that he could hear a noise like a rock rolling around inside the rear tire/rim on the left side (as you sit on the tractor). I hadn't appreciated it but when I cut RPM to 1100 and drove close my building I could hear it. Only present when tractor was moving. Wheel nuts were tight. Original tires, unfilled and never off the rims since I got the tractor new. Only about 60hrs on the clock and 50hr service hadn't turned up any problems. Seems to be working fine for mowing, FEL use etc.
Is this a normal noise I just hadn't appreciated before or is a sign of something more ominous? /forums/images/graemlins/confused.gif
Lyle
/ Noise from 2410 #2
Lyle,
On my B7500 I have to regularly tighten the hub bolts. There is a single bolt that tightens a shim on the axle on the hub assembly. Have you tightened them yet. Mine started making noise right around 60 hours too. I find it is easiest to do this with the wheels removed. Hope this helps.
Greg
/ Noise from 2410 #3
Sandalwood
GregJ is correct, check the torque on the hub bolts.
Lewis
/ Noise from 2410 #5
I HAVE A B2400 (earlier version of the 2410) never had any noise like that. if it is that noticable i would check the lug nuts(but think u would feel a loose wheel).
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Unverferth 6225 (A64119)
Unverferth 6225...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
2024 John Deere 561M Heavy Duty Round Baler (A63111)
2024 John Deere...
Caterpillar 955L Track Loader Service Manuals (A63117)
Caterpillar 955L...
