Noise from 2410
   / Noise from 2410 #1
sandalwood
New Brunswick, Canada
L5460 Kubota
I was using my 2410 HSDB yesterday doing light loader work and my neighbor who was helping me mentioned that he could hear a noise like a rock rolling around inside the rear tire/rim on the left side (as you sit on the tractor). I hadn't appreciated it but when I cut RPM to 1100 and drove close my building I could hear it. Only present when tractor was moving. Wheel nuts were tight. Original tires, unfilled and never off the rims since I got the tractor new. Only about 60hrs on the clock and 50hr service hadn't turned up any problems. Seems to be working fine for mowing, FEL use etc.
Is this a normal noise I just hadn't appreciated before or is a sign of something more ominous? /forums/images/graemlins/confused.gif
Lyle
   / Noise from 2410 #2
Lyle,
On my B7500 I have to regularly tighten the hub bolts. There is a single bolt that tightens a shim on the axle on the hub assembly. Have you tightened them yet. Mine started making noise right around 60 hours too. I find it is easiest to do this with the wheels removed. Hope this helps.
Greg
   / Noise from 2410 #3
Sandalwood
GregJ is correct, check the torque on the hub bolts.
Lewis
   / Noise from 2410
Thanks for the info Lewis and Greg. Will check torque on the hub bolts.
Lyle
   / Noise from 2410 #5
I HAVE A B2400 (earlier version of the 2410) never had any noise like that. if it is that noticable i would check the lug nuts(but think u would feel a loose wheel).
2008 Ford F-150 XL Pickup Truck (A53117)
2008 Ford F-150 XL...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
