Noco Chargers best sale yet
   / Noco Chargers best sale yet #41
Question for those of you who own these:
Lithium batteries do not like being stored long-term either completely full or completely empty. Most recommendations I've seen suggest storing some between roughly 30 - 80% (nd most seem to prefer the 50-80% range, since like most batteries, they will slowly dioscharge over time.)
How are you storing your boosters, and how often do you recharge when in storage?
i just charge to 75% and stop, and check yearly, hasn't been a issue
   / Noco Chargers best sale yet #43
When I purchased the lithium battery for my dirt bike, I also purchased the recommended charger. After charging the battery, there is a storage mode. It says you can leave it attached but I remove it and recharge a couple of times a year. Battery still appears OK after more than fifteen tears.
   / Noco Chargers best sale yet #44
The Lumber Wagon is my daily driver. It is a diesel and has a heater for better starting in cold weather. I would like to wire a charger/maintainer to the same cord. Is there a better one for a daily driver?
   / Noco Chargers best sale yet #45
The Noco units come with a 24" fused cable set with battery clamps. It has a connector that can be easily disconnected so you can leave the short cable attached to the battery. Just disconnect it when you need to use the vehicle.
I do this with both my tractors and just tuck the connector under the cowling. It has a cap to keep out road debris.
If you want to hard wire to the battery, you can use this accessory:
   / Noco Chargers best sale yet #46
I do this also with my tractor. Very handy in winter time
   / Noco Chargers best sale yet #47
I simply unscrewed the clamps and use the ring clamp directly on battery. Leave the connection outside the rig.
   / Noco Chargers best sale yet #48
Make sure you get something IPS 65 rated or higher if you are going to mount it on a vehicle. You might be able to get away with IPS 53, but I wouldn't risk it.
Find out what the wattage for your block heater is. I think they are usually in the 400-500 watt range. The max on a 15@ circuit is 1,500 watts. A 10@ battery charger should draw less than 120 watts, not bad, so a smaller trickle charger so shouldn't load things much.
Waterproofing the household plugs could be a marginal challenge if you tie them together permanently in the truck. But it's not rocket science.
I thought about this project on my tractor, but never got around to it. Mount a nice small weatherproof generator inlet box & socket somewhere. Burning 500 wats to heat the block long term is rather wasteful if you tie the trickle charger & block heater together. I've got remote controlled outlets to fire up the block heater if I remember to plug things in. But a trickle charger won't do much in an hour & turning it off most of the time defeats the purpose.
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A51248)
PALLET OF 2" X 4"...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
