Noco Chargers best sale yet
   / Noco Chargers best sale yet
Well, i only paid $99 for my noco10 about 3 years ago. And its worked great. I have no need for another 10 a, otherwise id be all over it.
it was 80, did the sale end?
   / Noco Chargers best sale yet #12
I saw the 2 amp version at Costco (North Canton, OH) for $25; was a couple of days prior to Thanksgiving. They had a whole lot of them at the store.
Man, our costco didnt have that.
   / Noco Chargers best sale yet #14
I don't know about the NOCO chargers, but I have one of their jump packs for diesels and I love it.
I have an old Sears battery charger that still works great.
   / Noco Chargers best sale yet #15
A reminder for those buying a NOCO GENIUS 1: This model is not water resistant. It is rated IP 60 (protected from dust intrusion, but the 0 means no water protection). It should be considered for indoor use only. Even if protected from rain/splashes, condensation can become an issue.
The rest of their Genius series of charger/maintainers are rated IP 65 (protected from water projected from a nozzle from any direction).
Their GEN series is rated at IP 68 (protected from immersion up to 1 meter deep). They are designed for onboard mounting on a vehicle.
I have a several pieces of equipment with small batteries that recommend charging at 1.5 Amps or less (UTV, motorcycle, forwarding trailer). It's hard finding a reputable, low amperage charger that is at least somewhat waterproof for these batteries (and especially one that has selectable charging profiles for both flooded lead acid and AGM batteries), so I have not mounted a charger on-board any of them yet.
   / Noco Chargers best sale yet #17
I have the 10, not aware of the jump start feature, do you mean force mode?
My Bad. It's not a Noco 10 it's a Noco Boost Plus GB40. Instantly jump starts anything with a battery so far..
ah figured that was it
   / Noco Chargers best sale yet #19
When using the Noco Genius 2 as a charger/battery minder, do you always unplug the Noco every time you connect to a battery?
I have one on the tractor which is more convenient to leave plugged in to AC because of the electric outlet location.
Can I leave the Noco plugged in...disconnect it from my tractor battery, use the tractor...and then just reconnect the Noco to the battery without ever unplugging AC to the Noco?
Anyone aware if it will damage the Noco doing this?
its fine the unit will just go in standby mode till you reconnect
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
