No wonder it was hard to control...!
   / No wonder it was hard to control...! #1
dbdartman
Platinum Member
central New Jersey (No. Burlco)
JD4400
Digging 6 holes today for trees being delivered tomorrow. As the digging progressed, control of the far end of the back hoe & bucket became more difficult. I finally looked at the lever controls & found this (first pic), supposed to look like this (second pic). After removal (3rd pic). :eek:
Being that scrap steel is pretty slim pickings here, I ended up cutting up a short piece of 2.25" square tube from an engine hoist leg I replaced a couple years ago. Used more of the same to reinforce the plate the grab handle & controls mount to.
After cutting & drilling the control plate & installing the stiffener plate behind the grab handle (4th & 5th pic), all was well again! I LOVE digging in the dirt! :D
So, am I the first here to have to replace one of these plates, or is this a common problem?
   / No wonder it was hard to control...! #2
Maybe a little spray lube (other than the bird **:D ), and put the covers back on. Glad you got it fixed.
Covers...? :eek: There's supposed to be covers somewhere on there?!? :confused: Seriously, what you see is what I got. I did lube all the rod ends with anti-seize compound. :D By next week, the tractor & all it's implements will be living indoors, so the birds will have to find another place to sit & ****! ;)
Giyi Mini Vibrating Roller (A53316)
Giyi Mini...
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
Michigan L90 (A47477)
Kennco V-Plow (A53316)
2008 New Holland B110 MFWD Loader Backhoe (A55302)
2008 New Holland...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
