Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,001
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I'm at work, 25 miles from home. Wife just called, says she was in shower and water died (power still on so it's not a power outage)
I said it's probably the breaker box and if not the breaker box, there is also a fuse box in the closet with the pressure tank.
She said "good... have fun with it, I'm leaving for work!!"
So... now I'm left wondering just what's going on.
Here's my line of thinking. Hopefully, the breaker gave. That's the easy answer. If not the breaker, maybe the fuse next to the pressure tank. I actually bought replacement fuses a while back just in case this ever happened.
What however, if those all prove to be ok... should I look at the pressure switch for chances of being stuck open?
If so, and the pressure switch seems to work fine... anything that can go wrong in the controller box that is attached to the pump? (I doubt anything in there that I could diagnose unless it's burned black!!)
Which I think then leads me to... could the pump simply have died after about 10 years?
I guess this would be the worst case, having the pump go out.
If the pump IS dead, does one typically replace the pump alone OR maybe the control box in the house with it??
Is the pump easily swapped out by a homeowner? I DO have a backhoe so I've got some hoisting power if need be. Although I don't really want to think the pump has gone south, I'm trying to prepare for that in the event I need to deal with it. What is involved with yanking a pump out of the ground?
Also... I don't have my notes here but the pump we have in the ground is supposed to give us 10gpm. In fact, it gives me closer to probably 30. That is also a guess since my notes aren't handy... point is, my well flows at about 100gpm and I only get a fraction of it. I have a watering system and have always wanted more flow.
If my existing pump is indeed bad and needs replaced... if it is also a "X" horspower pump, is there any benefit for me to get a "X + 1" HP motor to help gain more water out of the ground?
