Planters No-till planter vs. Overseeder
   / No-till planter vs. Overseeder #1
LabLuvR
SC
Kubota MX5400
Are they two different types of equipment? I want to plant some deer food plots and overseed some pastures. Just curious if there is one implement to do it all? Thanks!
   / No-till planter vs. Overseeder #2
From what I learned here on TBN they are two different beasts. An over seeder will plant seed closer together with more depth control and the trailing wheels will cover and pack the seed. It was said that a no till planter with the proper seed plate will do a reasonable job if you come back over the area with a culti packer to bed the seed.
MarkV
Okay, sounds reasonable. I'm still curious which of the two, if any, would be good for both food plots and pastures? I'm confused! LOL!!
Tried that search, no results. Thanks though.
   / No-till planter vs. Overseeder #7
In the big world of farming the no till planter saves money, time and erosion for the cotton and various other farmers. They spray grass killer as the planter rows and plants the seed. Generally for more row crops IMO.
I looked up the overseeder, that just looks like an expensive way to "plant" the seeds (winter rye for example), instead of just tossing them on top of the ground. they will probably come up better with this thing.
But are you just doing basic small deer food plots? Usually we just disk up the area, broadcast out some seed, then drag or lightly disk again.
   / No-till planter vs. Overseeder #8
A overseeder is for planting yards, lawns ect. were a 2" or 3" row spacing is needed for a thick planting. The no till drill will work fine for the food plots and fields.
They both have there place of use.
ddt
Thanks guys. I'm looking to start up a food plot business here in SC. The one implement I'm lacking is some type of planter. The no-till would probably be the best but also the most expensive. I'm having a hard time trying to justify the cost on a start up business. May just look at regular grain drill or row planters.
   / No-till planter vs. Overseeder #10
I sell a bunch of 71 planters on ebay. Do a search for corn planter to see a couple of them.
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2008 JLG SKYPOWER 800AJ MANLIFT (A51242)
2008 JLG SKYPOWER...
