no till drill
/ no till drill #1
crowe farm
mt washington ky
kubota m6800 / kubota 1400
anyone run a no till drill in the spring to sow grass . how heavy of ground can you run it or will it cloug up with mud . thanks
/ no till drill #2
Are you gonna use it on "black dirt" or sod field? Guess you already know.. plugging will be a pain with a tilled up field. And impossible - pert near - if it's even kinda wet. Drier is better (course that even applies to a regular drill).
AKfish
One additional consideration - if you're planting in dirt - you'll need to back way off on the depth setting and the down pressure. That makes a big difference in how bad the plugging might be.
/ no till drill #3
I'm considering renting a no till drill from the local coop in the spring guess they will show me how to use it i hope lol. I'm wanting to overseed my grass/hayfields to fill them in and make a little better hay.
/ no till drill
i want to overseed my alfalffa fields with orchard grass and timothy in the sprin the spring also . i dont want to rent it then the ground be to heavy and cant use it
/ no till drill #5
he only way i know of avoiding plugging a notill drill is to not plant in muddy sod.
/ no till drill #6
My wife rented a 7' Frontier, made by Haybuster, and sod drilled fescue into about half the pastures last Spring. It worked well, no clogging of course because no there had been no tillage. She put it behind the IH 574 and it knew it was back there, with about 400+ lbs of pressure on each opener it pulled on it a bit but it handled it fine.
/ no till drill #7
I rented this 10ft no till drill twice and it done a dandy job. I no-tilled alfalfa/orchard grass in soybean stubble and then the next year in sod. I did burn down the sod and used oats as a cover crop. It helps keep weeds at bay to let the grass and alfalfa get going. The oats grows fast providing a cover and I was able to cut it in late June/early July for hay.
/ no till drill
hoosier hay man how did you alfalffa do yhat you drilled have a good stand . thanks
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED IRANCH...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
