no till drill options for small acreage
   / no till drill options for small acreage #1
Chaostamer
Viola, ID
Mahindra 3215 w/ FEL & Kubota M6040 w FEL
We have 75 acres that we would like to freshen up pastures by seeding in grass seed. We also are revamping by spraying out and planting. I am wondering if there is a no-till drill that we could use with our 60 hp kubota tractor. Thoughts?
   / no till drill options for small acreage #2
Around here anyways you can rent no-till drills from the county NRCS office and they have small enough ones that your tractor could handle.
   / no till drill options for small acreage #3
I believe Land Pride makes a few small (<13ft) no-till drills - not sure if occasional use would be worth the prices though....
   / no till drill options for small acreage #4
There are several options. The land pride / Great Plains no till drills are very nice. They make a three point 3PT606NT that has a 60 hp minimum. The minimum is mainly due to being able to lift it. They also make the same drill in a pull type that requires less hp if you can’t lift it. They are not cheap though. 15-20k depending on options. They are very hard to find right now due to supply issues.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
XCMG CV83PD (A53317)
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
