No Start John Deere 5045D
   / No Start John Deere 5045D #1
Larry1776
John Deere 5045D
my 5045d will not start I parked it and tried to start it the next day it turned over a couple different times and now will not do anything. I had lights on the dash until I put a new battery in it. I have 12.7v to the starter which was replaced a couple months ago, all fuses are good but when I turn the key I don’t hear a click from the starter relay. Any thoughts?
   / No Start John Deere 5045D #2
Sounds like a safety switch is not working or the starter relay is bad.
Can you bypass the ignition and jump it at the starter?
   / No Start John Deere 5045D #3
My thought, have the battery load tested and clean both ends of the battery cables. Hope that one or the other solves the problem.
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
