No start after 17 years without problems on 2007 DK40se!
   / No start after 17 years without problems on 2007 DK40se! #11
Good job Lou!
  • Good Post
Reactions: D&D
   / No start after 17 years without problems on 2007 DK40se! #12
Sometimes the spade(Flag) terminal on the solenoid can get a little corrosion on it and starter won't turn with key. When you pulled the connector off and reconnected it, you cleaned the terminal and the starter worked again.
The salt air on Prudence Island can do that. I live close to ocean in Westport and I have to connect and disconnect the start terminal on my Kubota every year or so. It probably has a similar brand of starter. Never had to do anything more, but if you were fussy, you could get some electric contact cleaner and spray the terminal connector and the spade.
   / No start after 17 years without problems on 2007 DK40se! #13
I have a 2011 DK45 that had similar problems/symptoms several years ago. I had to replace the ignition switch.
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2003 CATERPILLAR D3G XL CRAWLER DOZER (A52707)
2003 CATERPILLAR...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
23013 (A55787)
23013 (A55787)
2017 Ford F-150 (A53422)
2017 Ford F-150...
