docrocky
- Joined
- Jul 18, 2011
- Messages
- 207
- Location
- NW Ohio and SE Michigan
- Tractor
- Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Tractor started and ran with occasional backfire. Then I decided to power wash because heavy dirt oil grime in front of engine and sides. No spark, afterwards plug and changed to new one etc. Have to remove entire grill and hood to get to the points and condenser in front of engine. Gasket in poor shape and the ring of the condenser exiting it wire cracked and fragmented. OK, obtained new points and condenser and installed with .020 gap. Fired right up. Then I ran it for a few hours cultivating weeds with row cultivator and on the last sweep, the engine dies. Gas ok. Oil ok. Now when I test with spark plug tester, no spark at all. So I went back to the points and condenser (having to remove all the front grill and hood) but find nothing amiss. I can not be sure that I am finding the widest gap before using the .020 . Not sure I am finding the TDC. The pin from the engine moves in and out freely but I can't seem to find the maximum throw so I can comfortably set the correct gap(it seems miniscule...less than a 1/16 throw). I am considering removing the head to see where the TDC of the piston is so that I can set the gap properly at the points or am I going in the wrong direction? I could go to the flywheel and check the ignition coil and magneto, but???? Any other suggestions???
