no reverse in high range tc33
   / no reverse in high range tc33 #1
jerrylee5
nashville, in
new holland tc33
I have a tc33 hst with 500 hrs on meter... the reverse gear seems to be weakening... little to none in high range. I have changed oil, and filters. and the oil seems to be full. bought this used 5 years ago with 300 hrs on meter.
any suggestions as to what needs to be done?
   / no reverse in high range tc33 #2
Have you checked under the footplate and floormat for some sort of obstruction to pedal travel in rev? May be nothing more than pedal not moving to full stroke.
   / no reverse in high range tc33 #3
Jerry Lee your TC33D has an HST transmission with both a forward and reverse pressure relief valve. If your pedals are fine as Harry suggested, it might be that you have a problem with the reverse pressure relief valve. It would make your tractor weak in all ranges, but in high range it would show the most. Just like a slipping clutch on a std transmission will slip more in high gears than low ones. Your dealer should be able to run a pressure test and verify if the relief valve is weak or defective.
   / no reverse in high range tc33 #4
There are "stop" bolts under the front and rear of your treadle pedal. Your rear stop bolt might have loosened up with use. Run the rear bolt down a little at a time to see if your condition improves.
thanks guys, it is weak across all ranges, most in high. I will check out the pedal. But my money is on the relief valve... would a little lucas help? It may be cheaper for me to put in a new valve.. any way for me to check this out or is this not for the DIYer?
   / no reverse in high range tc33 #6
By the time you buy all the stuff you'll need to do the checks, you could probably replace the valve. I would say certainly don't assume the relief is weak. That's why testing is so important. BTW: Hold your breath when you ask about the price of the relief valve. You may have to save your ice cream money for a month to pay for it.:(
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
