No PTO
   / No PTO #1
stykemainb
Davisboro,Georgia
JD X500, JD M 40T Tricycle
Ok I installed a new PTO on my X500 ran good for a while ofter I shut it off it would not come back on the light on the switch came on but no engagement replaced the switch still nothing any ideas anyone?
   / No PTO #2
Do you have a volt meter? If yes check to see if you are getting voltage to the clutch. If yes then suspect bad connection in the clutch or possibly the connector.
   / No PTO
If the connection is bad I should be able to put in a different connector right
   / No PTO
Can I put power directly to the clutch from battery to see if the clutch worls
   / No PTO #7
If you unplug the connector and then run wires from the battery straight to clutch you should hear it engage. Black wire on the reactor connector is ground. I do NOT know what colors the wires are on the clutch side though.
   / No PTO #8
Is there a safety switch in or on the seat?
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
