I’ve got a six spline gear pump on the old Case. Now that I’ve replaced the valve, I can’t get any pressure from the pump. I’ve got great return flow up to the brand new oil filter, but out of the filter only about a tenth as much as going into it. My du-Al loader has a vertical tank which is full, and there’s a ball valve just before the filter that I use to check on the flow. My question is, does the pump suck fluid in from the bottom of the tank? I don’t see how the dribble it’s getting from gravity could be enough. The pump is about 20 years old but only has about 50 hours on it at most and was working when I replaced the valve. Any suggestions much appreciated.
