No PTO output
   / No PTO output #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
Jinma 200 2005
My PTO has stopped driving the hydraulic pump connected to it. I can shift the speed lever 1000/off/540 and see a little movement on the PTO output shaft but no power to the shaft.
The pump will turn freely by hand. It was working a few months ago when I used it last. Any suggestions?
   / No PTO output
Is it the lowest lever? Almost on the floor? I tried it in the dark with the engine off. It is at what looks like the high position. I wll go back out in the morning. That lever is most likely. It was working and there has been no problems other than no drive.
Thank you Tommy.
   / No PTO output #4
Might simply be an adjustment of the lever that engages the pto gears.
or as happened on my FWD lever, the roll pin that locked the lever to the shift shaft sheared off. (was simple enough repair)
   / No PTO output
It was the PTO Engagement lever. I don't think I ever have used it. I must have pulled it up by mistake.
Thank you again Tommy.
   / No PTO output #6
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2016 CAT TL642C (A50123)
2016 CAT TL642C...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
434669 (A48836)
434669 (A48836)
