No power
   / No power #1
Swstratm
Cub cadet challenger
Needing help. I have a 2018 cub cadet challenger 750. I had to replace the starter gear due to a couple of broken teeth. After putting it all back together, I am getting absolutely no electrical power. I have checked the battery and it is good. I checked the fuses in the fuse box and they are all good. Have retraced all connections and they are all connected. Can’t find a good electrical diagram that shows connections and color code. Anyone have a similar issue?
   / No power #2
Welcome to TBN!
I assume you have power to the starter lug from the battery. Have you looked to see if one of the wires off of that lug is a fusible link and disintegrated, but insulation is intact?
   / No power
Yes. The starter lug is in good condition. I don’t even get any power to the instrument panel. It is as if I have a totally dead battery but it is perfectly good.
   / No power #4
Check, clean, tighten all four(4) battery cable connections. It's ls also possible fusible link has failed.
John Deere 450K , Open Rops, 6 Way Blade Dozer (A47371)
John Deere 450K ...
Bush Hog 7-Tooth Transport Chisel Plow (A49251)
Bush Hog 7-Tooth...
Woods Heritage RD60 Mower (A49251)
Woods Heritage...
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
New Holland 853 Round Baler (A49251)
New Holland 853...
2021 FREIGHTLINER CASCADIA DAY CAB (A50046)
2021 FREIGHTLINER...
