no power under load, stalls out
/ no power under load, stalls out #1
Scotte
Seabrook, NH
873 bobcat
I have a bobcat 873, been setting for 6 months, starts fine, idles strong and drives okay. When putting it under a load like lifting or grading it dies out. Seems like a fuel problem, changed the external fuel filter and added Lucas conditioner. Worked for a few minutes, same issues. I would like to drain fuel, add new fuel, conditioner, and filter. Is there another filter? Any suggestions?
/ no power under load, stalls out #2
Have you checked for good fuel flow from tank.? I wonder if your machine has a "fuel lift pump"? Dino diesel doesn't go bad nearly as quickly as gasoline.
/ no power under load, stalls out #3
It does have a lift pump. There is a screw and cap on top of the lift pump, take that off and you will find a screen in there. Try cleaning the screen. Some very early 873s had a screen on end of pickup tube in the tank.
/ no power under load, stalls out #4
Have you checked the air filter..??
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
2012 Infiniti QX56 SUV (A64557)
2012 Infiniti QX56...
