No power to dash
/ No power to dash #1
Lazer
Woodbine, NJ
Kubota B9200
Hey folks! i recently changed the fan belt on my Kubota B9200. Since then I've lost all power to the dash ie fuel gauge doesn't work, lights will not turn on etc.
Im at a loss and am quite terrible with electrical issues. Any thoughts would be greatly appreciated.
Thanks!
/ No power to dash #2
A good starting point to troubleshoot would be checking the fuses. Then maybe a visual check up behind the dash for any obvious problems like loose wires, etc.
/ No power to dash #3
Changing the fan belt should have had no effect on electric stuff in the dash. Go back over your installation and see if you could have pulled some connector loos and as ptsg suggested it wouldn't hurt to check fuses.
/ No power to dash #4
Is your dash (and other stuff) fed off the alternator? Maybe moving it to get the belt on buggered up the connection. That is the only immediate connection I can think of.
/ No power to dash #5
On many applications the alternator is uses to tension the fan belt.... I would check the alternator for loose connectors or broken wires since the is where you were working....
Dale
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2022 EZ-GO ELITE...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
Bucket (A64194)
Bucket (A64194)
