No power after battery change on New Holland Workmaster 33
   / No power after battery change on New Holland Workmaster 33
no, all are tight
   / No power after battery change on New Holland Workmaster 33 #12
Sounds like you both batteries you were trying were used, but re-charged.
Batteries can be an enigma, especially when temps are colder than normal.
If it were me, I’d buy a brand new battery tomorrow and see if that fixes everything. Worst case, you have an extra battery (or return it).
   / No power after battery change on New Holland Workmaster 33 #13
I did sand the spot where it grounds, cable is brand new just bought today. I didn't sand it to the point that it is bare metal but definitely enough that no debris would be there.
This has me suspect:
You need metal to metal contact.
Take your volt meter and check continuity from the negative battery post to some other bare metal on your frame. If your battery tested good it should at least have enough power to energize your dash lights.
2008 Ford Focus Sedan (A55758)
2008 Ford Focus...
19015 (A55788)
19015 (A55788)
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
