No oil pressure
   / No oil pressure #1
willhoff
new concord, ohio
john deere
I have a JD 6405 with a SyncroPlus Transmission. The transmission had 75 psi of oil pressure which is low. I pulled the transmission. Everything looks good so I put a new pump, seals, O-ring in the unit and put it back together. I started the tractor everything worked good. I shut the engine off and topped the transmission oil off then started the tractor again. It wouldn't move. I have zero oil pressure. I pulled the transmission again and everything looks good. Any Suggestions??
   / No oil pressure
Air pocket in system (cavitation in pump?), any way to purge the pump and lines?
Dale
I didn't hear the pump cavitating when it was running and the pump was working for a time. The oil pressure check point is basically beside the pump so there is no oil lines to bleed. I wouldn't think air could be trapped in this system.
   / No oil pressure
Relief valve stuck open?
It looks like there is two valves that regulate the oil pressure in that transmission. It has a Pressure Regulating Valve and a Engagement Override Valve. I disassembled both valves. The spools where clean, no marks or scratches and they moved freely in their ports. The springs looked good and they measured the specified length. I don't have a way to test pounds of torsion on the springs but I was satisfied they are not at fault and put the valves back together.
378632 (A51573)
378632 (A51573)
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
