3-Point Hitch no movement
/ no movement #1
lockhaven
out
kioti ck30
Any information or advise would be appreciated. My 3-point hitch has stopped working. I went to lower it and nothing happens lever works fine and is turning a plate on the housing. The hydraulics are working ok on the FEL fluid is at the proper level. When I work the lever nothing seems to be happening no engine change or any straining sounds. I do not use the 3 pt hitch very much but until today it has always worked. The tractor is a CK30 gear with 118 hours Thank for any incite on this.
/ no movement #2
Not sure this would explain "no working" but there is a knob under the right leg as you sit in the seat that changes the speed of 3pt action. It might have gotten turned all the way to "turtle". My 3yr old and 6 yr old grandson spend some time on mine this weekend and I had some knobs and switches turned.
/ no movement
thanks and that is just what happened, I do not know when but after checking that is what happened. I panicked and got scared and the brain stopped working. Thanks again
/ no movement #4
Don't worry, your not the first to panic when that happened. I was ready for a recall because I knew it could not be my slip up. :D
MarkV
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
