3-Point Hitch no movement
   / no movement #1
lockhaven
Platinum Member
out
kioti ck30
Any information or advise would be appreciated. My 3-point hitch has stopped working. I went to lower it and nothing happens lever works fine and is turning a plate on the housing. The hydraulics are working ok on the FEL fluid is at the proper level. When I work the lever nothing seems to be happening no engine change or any straining sounds. I do not use the 3 pt hitch very much but until today it has always worked. The tractor is a CK30 gear with 118 hours Thank for any incite on this.
   / no movement #2
Not sure this would explain "no working" but there is a knob under the right leg as you sit in the seat that changes the speed of 3pt action. It might have gotten turned all the way to "turtle". My 3yr old and 6 yr old grandson spend some time on mine this weekend and I had some knobs and switches turned.
   / no movement
thanks and that is just what happened, I do not know when but after checking that is what happened. I panicked and got scared and the brain stopped working. Thanks again
   / no movement #4
Don't worry, your not the first to panic when that happened. I was ready for a recall because I knew it could not be my slip up. :D
MarkV
   / no movement #5
I had the same thing happen.:D
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
