Tiller no luck with iseki tiller any suggestions?
   / no luck with iseki tiller any suggestions? #1
agcomike
southern states
Hinomoto e2004 aka 5020
I have a iseki tiller 4.5' and here i have hard clay it's been realy wet but when i've tilled it's been dry..
But i have 2-3" clod's every where any suggestions on using the tiller to fix this? the tiller has the straight tines ... do i just need to buy a L-C shapped tine tiller?
I subsoiled it then tilled it 3 times.. let dry out then sub soiled it agian then tilled it 3 times and then let it dry and now it's a cloddy mess..
   / no luck with iseki tiller any suggestions? #2
It sounds like you need new tines. Your tines should be "L" shaped. As tines wear out the bottom of the "L" wears off and you are left with a straight tine.
   / no luck with iseki tiller any suggestions? #3
No experience w/ straight tines.. but w/ L tines.. if you are getting clumps.. the size of baseballs.. it usually means the soil is still too wet to till. Can the straight tines be replaced w/ L tines on that brand tiller.. less $ than buying a new one.
Where can i find new tines at? I have the iseki model # would it cross with a ford/new holland or are tiller tines universal?
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2014 BMW 328i Sedan (A50324)
2014 BMW 328i...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2013 Kubota M9960 (A50120)
2013 Kubota M9960...
