no high gear
/ no high gear #1
cosmic chief
Geelong Australia
eastwind dfm 254 4wd 25hp tractor
I have a eastwind tractor when I put it in high gear it go's real slow and then justs stops .It works ok in low gear need help doing my head in
/ no high gear #2
By it going real slow in high gear, do you mean, it goes real slow in 8th gear, or in the entire high range? Does it have sufficient power in the other gears?
/ no high gear #3
If the engine speed doesn't change when the tractor comes to a halt, that suggests that your clutch needs either adjustment/repair/replacement. A burnt friction disc on the drive disc is often the problem, especially for those who can't break the habit of riding the clutch. If the engine bogs down, you're simply in too high a gear. Either go down a gear or two, or drop into low range.
//greg//
/ no high gear
It works fine in th four low gears but when u drive it say in second gear it go's for about 10to20 meters and then stops and then it go's again real slow.The thing is that it was working great the day be for I moved about 4 meters of crushed rock and spread it never played up once.Parked it up for the nite and its like this the next day.
/ no high gear #5
Can you run it fast, within the recommended rpm range, in 4th gear, for an extended period without it bogging down. I'm trying to determine whether you have a resricted fuel flow.
/ no high gear
Dose anyone no of a tractor mechanic in the geelong area that would be able to come out and take a look at it please
/ no high gear #7
Don't know if you are understanding the questions being asked or not.
Simply put when you have it in high gear and the tractor physically starts to slow down does the engine rev speed continue at the same rate/increase..................or does the engine speed also die?
You are probably looking at paying $100 an hour for a mechanic to look at it plus about $100 call out fee.......may as well have some idea whats wrong with it before you start paying out money
/ no high gear
The engine rev speed continues at the same rate it does not increase or die it just stops moving and u sit there and then it moves slow
/ no high gear #9
You burned out the drive clutch while moving that material. Classic result of riding the clutch during loader work.
//greg//
/ no high gear #10
As Greg said the clutch is either burnt out or is badly out of adjustment...At least now you can ask a mechanic for a quote.....or if you are mechanically inclined you can do it yourself..involves splitting the tractor but it is a straight forward job.
/ no high gear #11
As others have noted, your clutch is slipping. Most likely this is caused by the clutch disk wearing out, which means replacing the disk, which means splitting the tractor in two. A while back there was a mechanic here who was bragging he could do a clutch in six hours. I think that's under ideal conditions, with a well-equipped shop and on a tractor he was familiar with. I think an experience mechanic with the right tools could probably do it in under twelve even if not familiar with the tractor, they're pretty straightforward. In terms of parts, I did the clutch on my Jinma last summer and it was US $155 for new disks for the drive and PTO clutches, and a new bearing. So the cost of the job is mostly labor.
There are two other possibilities. One is that the clutch is misadjusted. What that means is when you take your foot off the pedal, the pedal is actually still pressing slightly on the clutch. The clutch pedal moves a fork which presses on the clutch bearing, the clutch bearing presses on the clutch release. There should be a gap of about 2.5 mm between the bearing and the release. There is an inspection plate on the side of the housing that you can take off and look in to see the gap, but you can sort of tell without even looking there, the pedal should feel like it has maybe 20mm of movement before it does anything.
The other possibility is your clutch is slipping because it is contaminated with oil. To fix that you have to find out where the oil is coming from and fix it, it could be anywhere. I've had clutches where the oil burns off by itself, but it may also mean splitting the tractor and replacing the clutch.
/ no high gear
Why would it do that over night I stop for about a hour or two while I was moving the rock and it worked fine
/ no high gear #13
That would be consistent with an oil leak. I had a car once that had a slow leak on a transmission seal. It drove fine, except for first thing in the morning when it had had time to leak all night. There was a big hill near my house, and when I went up that hill in the morning the clutch would slip until all the oil burned off. Then it would be fine for the rest of the day. It was bearable for a while, then I eventually fixed the leak.
/ no high gear #14
A number of owners of Chinese tractors have had issues with inadequate assembly at the factory resulting in oil leaks from either the main bearing seal or the oil sump-to - lock joint. Either one can result in oil being drooled into areas where it gets on the clutch friction disc. The only cure is to split the tractor and clean everything up, replace what you must, and reassemble properly with everything torqued to spec and sealed as appropriate. I did my tractor and everything has been fine ever since. Took me a weekend to split it and get things done right. IUf I'd had assistance I think I could have done the whole job in one day, but working alone took two days.
/ no high gear #15
As others have suggested in could be oil getting on the clutch plate............Feel at the bottom of the bell housing (The big casting that the engine bolts to ) there should be a small drain hole there. Just check with your finger if the is oil present there. If it is you all most certainly have an oil leak inside there somewhere.
/ no high gear
Will have a look at that zonat223 and let you no if there is any oil in there if no oil means clutch is gone either way the tractor has to come in half to fix it right
/ no high gear #17
Heat.... Things expand with heat and it was just enough to "adjust" the tolerances.
I actually doubt its oil. Usually oil or grease has the opposite effect than you would think and makes it grabby.
Listen to the advise you are getting. You have a damanged clutch.
Chris
/ no high gear #18
I would have a quick look to see if its adjusted correctly you may be lucky...............but honestly think you will probably have to split it.
/ no high gear #19
If you are one of those who simply cannot take his foot off the clutch, the drive disc is in almost constant contact with its pressure plate. Decreases drive clutch life is inevitable. Moving that material was probably all it took to burn off any effective surface left on the disc. I'm gonnal speculate that you'll eventually find the surface of that disc to be be ringed in dark brown to black and have a glossy appearance. And as stated, oil will saturate the friction material and often cause it to separate from its plate. Smooth oily surfaces and/or missing material is what makes an oily clutch "jump"
//greg//
/ no high gear
Have not been on here for a long time just thought I would let you all no that the clutch was not burnt out or oil on the clutch .The problem was that the 4wd leaver had broke and half in 4wd and half in high gear so there you all go
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2016 John Deere HPX Gator 4x4 Gas Utility Cart (A61567)
2016 John Deere...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
