No FWD or Reverse after drive belt change
   / No FWD or Reverse after drive belt change #1
mattig
l3560
After changing the drive belt on the LTR 180, no wonder those center chute rear-baggers were discontinued. What a chore. (Edit: apparently not discontinued as the design lives on in the X350R).
To make matters more frustrating, after patting myself on the back for a job well done on the belt, I have no forward or reverse. Blade spins beautifully, but there is zero indication of anything happening when pressing fwd/rev pedals. It is not the free-wheel lever. I checked that first. I can hear hydraulic fluid pumping normally with the motor off while pressing pedals. I'm 99% sure I have the belt routed correctly through the gauntlet of stupid pulleys at the rear of the mower. I'll take off the deck and the chute this afternoon and put it up on blocks to verify the drive belt is moving, and then go from there.
Any other ideas from the brain trust?
   / No FWD or Reverse after drive belt change #2
A simple thing like twisting the belt the wrong way would mean the hydro pump is running the wrong direction. Double check belt routing and twist.
Ok, looks like the belt was routed correctly, but one of the springs wasn't seated in the correct notch. Either that did the trick or it just needed more time to work all the dust off the belt. Yee haw! Avoiding buying a new mower for yet another week!
   / No FWD or Reverse after drive belt change #4
There ya go! (y)
   / No FWD or Reverse after drive belt change #5
I absolutely hate the design of these motion drives. If you can pull this off, you should be darn proud.
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
