No fuel to carb jd 420
   / No fuel to carb jd 420 #1
OutbackL130
chickamauga
L130, 420
I'm trying to start the engine while finishing up my jd 420 restoration. The engine ran on the gas in the carb, but once that was used up it died out.
I had replaced all the fuel line, filter, cleaned the tank out and put new gas in. There is no fuel being pumped to the engine and the fuel filter is empty.
It must have just needed to be primed. I sprayed more gas directly into the carb and let it run on that for a few minuites and it started pumping.
The problem now is I cant get it to idle right. The engine surges unless I pull the choke out half way. Does this sound like the carb needs to be cleaned? The only other thing is I might have switched up the spark plugs wires. Whoops. Would that cause this problem or a dirty carb?
   / No fuel to carb jd 420 #3
Outback I would start with carb. Take it apart and soak in carb cleaning solution and blow out all passages after soaking. Seafoam should finish what still remains
1/8" X 41" W X 81"L DIAMOND PLATE STEEL SHEETS (A51247)
1/8" X 41" W X...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
BUNDLE OF MISC SIZE PINE (A51248)
BUNDLE OF MISC...
JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
JOHN DEERE CP 770...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2019 Hustler Super Z 60in Zero Turn Mower (A51691)
2019 Hustler Super...
