DavesTractor - Thanks for the insight. Question - what part of the front end do you suggest I tear into? Out at the wheel? The top of that assembly? Bottom? Or do I get into where the driveline comes into the axel?
Thanks!
Aaron
It is hard to know how to answer without seeing the tractor, listening to the issue and so forth. I think I would check first where the driveshaft connects to the front axle. Remove the cover and look that over. If that looks fine, start at the hubs and work inward. Lastly would be the ring and pinion. It is not a common failure on these tractors, so I have no real insight on where to focus. We have seen a few ring gear failures, but that becomes more obvious.
I will say that almost every time I have seen a ring gear failure on a front axle of one of these it was due to improper usage of the tractor. Often a guy is fetching heavy loads of wet sand out of a creek and backing up the creek bank. 90% of the entire tractor and heavy load is on the front axle and they are backing up a hill needing quite a bit of power. The rear tires are just about in the air, giving no help. The front axles are made to assist, not to do all the work or even the majority of the work. Front axle components on all compact tractors are much smaller then rear axle components.
The other way to break an axle, of any brand compact tractor, is to use the front loader to push out a tree or stump. You get the bucket in a really good spot, lift hard and drive forward. One of just a few outcomes are available in that scenario. Either the stump gets pushed out, the front tires spin (but they won't as you are pressing a huge load down on them), the clutch slips, the engine dies or you break your front axle. It all happens quicker than the time needed to read that run-on sentence.
I throw out those scenarios in no way meaning that you have done any of this. Others will read the thread and maybe think about the dynamics of how they load up a front axle. I've broken and bent some things myself over the years. It is better to learn from other's mistakes than to make them yourself.
