No forks, but the tooth bar works!
   / No forks, but the tooth bar works! #1
Singlecoil
Eatonville, Washington
Kubota BX-24D Cub Cadet LT42e
I had to move a 400 pound generator by myself and came up with a rope and wood frame combo. At first I thought I was going to use the backhoe and some sort of crossbeam to lift the thing, then I though I could just hook the ropes on the tooth bar teeth and I was good to go. It would have been much simpler if I had forks and had just left the thing on the shipping pallet, however.
   / No forks, but the tooth bar works! #2
Good work.... I've used my FEL toothbar on numerous occasions like this...typically with chains. My portable generator has permanently installed ropes so I can pick it up and carry it to the pasture or put it into the back end of the pickup... sure saves the back.
   / No forks, but the tooth bar works! #3
This strategy seems to take the place of chain hooks on the bucket ... any downside to using the toothbar as opposed to chain hooks?
Thanks
JR
   / No forks, but the tooth bar works! #4
I would highly recommend that you purchase a set of chain on forks. I paid around $220 for a set with racheting chain tesnioners, and they are really useful. I have used them for:
- Picking up large piles of brush
- Picking up 10 foot logs
- scooping up and moving 10 or so 5 inch treated posts. Did this multiple times
- Easily moving my 3 point hitch equipment around, as well as my mid mount mower. Picks up the box blade like a charm, and makes moving the MMM a breeze.
- Moved a pallet with apporx. 650 lbs of Ramm Fencing on it. This was the limit for my tractor, but I moved it slowly
- Moved 7 bales of hay at a time on a pallet.
A real must have in my opinion, and very cheap for the utility they provide.
How about a picture? That sounds pretty good.
Thanks
JR
I think it mainly depends on the angle you need to apply the force. In this case the toothbar worked fine, but if you wanted to secure a big stump in the loader or something it wouldn't work at all.
   / No forks, but the tooth bar works! #7
Singlecoil is right... there are places and situations where either the toothbar or chain hooks are the better attachment point... I wouldn't be without both.
   / No forks, but the tooth bar works! #8
Even though I have a set of forks, I've done the same thing with the toothbar on my loader. Just depends on what is closer, and what I need to lift & move. I would suggest a chain, though, simply to prevent fraying the rope or straps on any sharp edges of the toothbar.
   / No forks, but the tooth bar works! #9
I have used my tooth bar a few times for lifting. In fact the last time was a new Briggs & Stratton 8,000 Watt generator out of the back of my truck. It was 200 odd pounds. The only fear I have is the strap slipping of the tooth. I would really like to add hooks but I would rather have them welded and not bolted.
197390 (A50459)
197390 (A50459)
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
