No flashers or Turn signals
   / No flashers or Turn signals #1
RWBTC34
King George VA
NH TC34DA
Next up after getting the old girl running is to try to figure out why the flashers and turn signals don't work. TC34DA. head lights work but no flashers or turn signals ... I did find a "brick" inside the dash with lots of functions listed... to replace that is $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
Cheers
   / No flashers or Turn signals #2
Cheers
Usually a replaceable relay and timer.
Sometimes they don't work if too many bulbs out or bad ground too.
   / No flashers or Turn signals #3
My tractor turn signals, flashers would not work when i bought it; traced it down to corroded contacts in the switches. It cost me $9 for a spray can of contact cleaner, and 5 attempts to remove the corrosion inside the switch. All is fine today.
   / No flashers or Turn signals #4
Cheers
This series uses a flasher/turn signal module that resides just below the steering column mount.
The flasher relay should be the first relay on the second row.
Switch it out with a known good relay of the same type off the board and see if it works.
If not, put a multi at the module to see if you’re getting any output.
Module is around $190.
Lotta money for not such an important feature.
Hopefully it’s just the relay.
Kuhn Knight Vertical Maxx 5144 Mix Feed Wagon (A50514)
Kuhn Knight...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR D6T XL HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
John Deere 637 Disk (A50514)
John Deere 637...
