No Ethanol
   / No Ethanol #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Found a local auto parts store that sells ethanol free gasoline by the gallon. At $17.95/gal it's steep but it's 94 octane and guaranteed for 2 years. AvGas at the local airport is $6.20/gal. Think I'll head to the airport come fall.
   / No Ethanol #2
Ethanol free 94 octane is about $3.90 here. Several of the local stations have it.
   / No Ethanol #3
our ethanol free gas is 90 octane $3.78 a gallon i just went and got 15 gallon's today. marathone is our only sorce for it here.
   / No Ethanol #4
Haven't priced it yet, but if you need mixed gas, Stihl has the 92 octane 50:1 Motomix. At least up here in Canada.
http://http://en.stihl.ca/motomix.aspx
Info below, taken from the Canadian site. Must be ultra stable stuff, (at least compared to pump gas today) as they are quoting 2 years after the can is open. Rgds, D.
Motomixョ Premixed Fuel
NEVER WORRY ABOUT MIXING AGAIN!
New ethanol free, fully synthetic and highly biodegradable premixed engine fuel.
Right mix: Perfect 50:1 mixture of 92 high-octane fuel and the protection of STIHL HP Ultra two-cycle engine oil
Longer shelf life: 2 years once seal is broken*
Environmentally Conscious: Non-aromatic fuel; fully synthetic, highly biodegradable engine oil
Extended Warranty: Two year warranty with purchase of 3 cans of MotoMixョ (ask your STIHL Dealer for details)
* It requires to be stored in a cool, well ventilated area to avoid vapour build up. Avoid prolonged exposure to temperatures in excess of 120˚F /48˚C.
   / No Ethanol #5
Ditto, same stuff here runs $4ish a gallon and one station in West Memphis, AR has it around here.
I run it in everything with a carb on it and the difference in ease of starting in performance is simply AMAZING.
I call it Viagra gas for my old 25 horse Johnson 2 cyl / 2 stroke - it makes its sticker peck out!
   / No Ethanol #6
Only 87 oct ethanol free is available at filling stations around here :(
   / No Ethanol #7
I haven't found any ethanol free gas in my area, wish I could. None of the marina's I have talked with have it either. :(
   / No Ethanol #8
There are a number of websites including buyrealgas dot com that list where you can buy ethanol free.
   / No Ethanol #9
Those lists are not updated causing me to take a unsuccessful trip.
   / No Ethanol #10
It is fairly common around here as most of the commercial lawn service companies use it and there is a demand. Also, it is usually readily available around boating areas and runs about a dollar more than the same octane ethanocrap fuel. 100LL Avgas is not a good substitute for modern small engines as the lead causes issues with them. There is some 96 octane racing fuel around in areas with auto tracks. Check the website puregas.org for stations in your area.
Small Trailer frame (A53117)
Small Trailer...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
UNUSED (2) 30PCS Grey Metal Roof Panels (A53117)
UNUSED (2) 30PCS...
FAKE (A52472)
FAKE (A52472)
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
