No electrics 2120 New Holland
   / No electrics 2120 New Holland #1
lenny69
Ilion,NY
New Holland 2120
I have a 1998 2120 tractor and the fuse on the red wire coming off the starter blows when ignition switch is turned on. There are no electrics at all none of the gauges work either. I have traced wires and can't find any dead grounds or burned wires. Other fuses are good. Any ideas
Disconnect the large wire hooked to the alternator.
I disconnected the red wire on alternator and when I turned key it blew the fuse again. Thanks for your response thou.
   / No electrics 2120 New Holland #6
Welcome to TractorByNet!
We moved your thread to the New Holland Owning & Operating forum. :)
   / No electrics 2120 New Holland #7
Did you check the ignition switch for the short?
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
