No electrics 2120 New Holland
   / No electrics 2120 New Holland #1
lenny69
Ilion,NY
New Holland 2120
I have a 1998 2120 tractor and the fuse on the red wire coming off the starter blows when ignition switch is turned on. There are no electrics at all none of the gauges work either. I have traced wires and can't find any dead grounds or burned wires. Other fuses are good. Any ideas
Disconnect the large wire hooked to the alternator.
I disconnected the red wire on alternator and when I turned key it blew the fuse again. Thanks for your response thou.
   / No electrics 2120 New Holland #6
Welcome to TractorByNet!
We moved your thread to the New Holland Owning & Operating forum. :)
   / No electrics 2120 New Holland #7
Did you check the ignition switch for the short?
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
Eagle Weathervane (A55853)
Eagle Weathervane...
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
