No dip sticks on trans. or hyd. cases. how much fluid?
   / No dip sticks on trans. or hyd. cases. how much fluid? #1
krogers
ford jubilee
The manual I downloaded for my NAA says to check the fluid levels on the trans and hyds with the dip stick. Even says the hyd case has a dip stick on the right side of the case. There are no sticks that I can find. There are large filler holes so I can look into the cases to see the fluid levels. Should I just fill them up to near the top?
   / No dip sticks on trans. or hyd. cases. how much fluid? #2
Do not fill them to the top. This is a picture of my 8N but I believe it should be the same deal with your NAA. If the dipstick is missing from this location, remove the bottom bolt that is circled and fill to where the hydraulic fluid starts to run out of this bolt hole:
   / No dip sticks on trans. or hyd. cases. how much fluid? #3
Your dipstick is on the opposite side of your tractor from the image above. If you drain the system it should hold 2 gallons to be full.
Yes I found it. Thank you.
40ft Hay Conveyor (A49251)
40ft Hay Conveyor...
Boss Snow Plow (A49251)
Boss Snow Plow...
2015 John Deere 210G Hydraulic Excavator (A46683)
2015 John Deere...
Golf Cart (A48082)
Golf Cart (A48082)
2012 KENWORTH T800 (INOPERABLE) (A48992)
2012 KENWORTH T800...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
