no curl strenght on loader,
   / no curl strenght on loader, #1
ddmargo
Erie, Pa.
1990 Wheelhorse 312H, 1974 Case 444, 2009 Kubota 2360
no curl strength on bx loader,everything else is ok. help...:
   / no curl strenght on loader, #3
Welcome
as magicheater said more info
my crystal ball is broken:laughing:
what bx
up / down
switch both hyd lines with lift and see if lift works the curl and if lift will curl
tom
   / no curl strenght on loader, #4
If you're running into a gob pile and expect the curl to pick up a full load, it's not going to happen. Pull in to the pile, curl up some and raise the bucket while moving forward. This will slice a layer off of the front of the pile, filling the bucket. Takes a lot of practice to perfect the procedure but thats what it takes with these small TLBs.
   / no curl strenght on loader, #6
about your loader
as the loader is a loose materials bucket it is only ment for gathering loose unpacked materials. most likely you are overloading it and the main releif valve is opening due to pressure spikes from the loader valve.
If you had a bad cylinder that was bypassing you would not be able to keep the bucket retracted or level.
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2000 Ford F-350 12FT Stakebody Flatbed Truck (A51691)
2000 Ford F-350...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
2013 Ford Explorer AWD SUV (A51694)
2013 Ford Explorer...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2017 Kia Sedona LX Van (A51694)
2017 Kia Sedona LX...
