no curl strenght on loader,
   / no curl strenght on loader, #1
ddmargo
Erie, Pa.
1990 Wheelhorse 312H, 1974 Case 444, 2009 Kubota 2360
no curl strength on bx loader,everything else is ok. help...:
   / no curl strenght on loader, #3
Welcome
as magicheater said more info
my crystal ball is broken:laughing:
what bx
up / down
switch both hyd lines with lift and see if lift works the curl and if lift will curl
tom
   / no curl strenght on loader, #4
If you're running into a gob pile and expect the curl to pick up a full load, it's not going to happen. Pull in to the pile, curl up some and raise the bucket while moving forward. This will slice a layer off of the front of the pile, filling the bucket. Takes a lot of practice to perfect the procedure but thats what it takes with these small TLBs.
   / no curl strenght on loader, #6
about your loader
as the loader is a loose materials bucket it is only ment for gathering loose unpacked materials. most likely you are overloading it and the main releif valve is opening due to pressure spikes from the loader valve.
If you had a bad cylinder that was bypassing you would not be able to keep the bucket retracted or level.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51691)
2017 Mack GU713...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
