No cost Gravely dual wheel spacers.
   / No cost Gravely dual wheel spacers. #1
bobodu
Platinum Member
Whitley County,In.EIEIO
Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
After spending too much money refurbishing my Gravely Model L and being outbid
too many times on Ebay,I went in search of a cheaper alternative to
purchased wheel spacers.I found a piece of steam header pipe down at
the shop that measured 3 1/2 inches in diameter.I cut two lengths 5
inches long.A length of 1 1/2 X 3/16 inch angle iron was cut into
twelve pieces one inch wide.These were simply mig welded to the sides
of the pipe,three per end.I made a circle on a piece of plywood and
divided it into thirds (120 degs.),extending the lines out about a
foot to use as a guide to make sure the angle iron would cover the
bolt holes.It only took a second on each piece of angel with the
grinder to get them to fit inside the wheels.Drill out the holes (I
just set a wheel on the spacer to get them centered),go to the coffee
cans for the nuts,bolts and washers.If you tack weld the bolts on one
end of each spacer facing out from center it makes mounting a
breeze.Now,just grind down any rough spots and give them a nice shiny
coat of paint.Mount your spacer to the tractor and mount your outer
wheel.Done.Total cost....nothing!! Somehow...they actualy run true.Bob.
   / No cost Gravely dual wheel spacers. #2
bobodu,
You forgot to post the pictures! /forums/images/graemlins/grin.gif
Interesting solution and sounds like a nice project.
Post a couple pictures of the tractor with the dual wheels on it if you can...
Got too many projects going on right now to tear down the wheels for a picture of just the spacers but I am more than happy to show you my baby.Bob /forums/images/graemlins/laugh.gif
Just another shot taken from the front.Can't wait for the decals to get here.Have added some wooden handles this morning.I used file handles from the home improvement store and am saving the originals.Bob
   / No cost Gravely dual wheel spacers. #5
</font><font color="blue" class="small">( Got too many projects going on right now to tear down the wheels for a picture of just the spacers but I am more than happy to show you my baby.Bob /forums/images/graemlins/laugh.gif )</font>
When you do get the chance to take the wheels off, post photos. A tutorial would also be nice as to your procedure. A picture is worth a thousand words! /forums/images/graemlins/wink.gif
By the way, nice looking unit. Looks very aggressive!
Some pictures of the spacers...
Another angle..
A shot from the end..
And one with them on my tractor...
   / No cost Gravely dual wheel spacers. #10
Thanks for the photos. Good luck with your dual wheeled Gravely. /forums/images/graemlins/smile.gif
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
FLOOR JACK (A53843)
FLOOR JACK (A53843)
SET OF (4) 11R24.5 TIRES (A53843)
SET OF (4) 11R24.5...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
