No change in RPMs
   / No change in RPMs #11
Its a TEMPORARY FIX.. go get some atf & acetone & let it sit.. that'll eat the rust off the parts.. then do as before.. pull the stop, crank it over a few times & let it sit some more.. Drain & refill w/ regular engine oil to the FULL screw & run it..
I know it makes you feel warm & fuzzy to get it running.. but ....
   / No change in RPMs
Man, PumpGuy knows his stuff!
Today I drained the acetone mix from the pump. Guess what it looked like? Brown baby poop! (I should have taken a photo, as others may not believe me.) Put in the recommended oil and ran it for 2 hours. Nice smooth throttle response, full-spec top speed, and no-stumble idle.
This 1966 runs better than my 1991 tractor. (My only complaint is my left knee is aching from working that long travel clutch.)
   / No change in RPMs #14
Good going.. always nice to hear a success story.. happy to help.. Happy tractoring..
   / No change in RPMs
Anyone want me to pick a lottery ticket number for you?
My wife and I were at her sister's house this morning. She's mowing with our little tractor as I tried to repair their ZTR. (The sister is out of town on an extended work assignment.) I had to give up on the ZTR, so went to check on DW. I smell something and see her mowing deck on fire. I wave her down and run with a bucket of water. The grass inside the deck had caught fire when a spindle bearing overheated. So we go home where I have the sister's Ford 3000 (where I've changed out the gearbox on that mowing deck yesterday). I start the tractor, it dies and won't restart.
Tried to start my motorcycle a few days ago and it won't start. (You have to know a bit about me, here. I shut off the fuel to my gas engines and burn out the line so the carb is nice and dry before I put it up. I normally never have problems starting stuff up.)
As the old gold miners used to say: I just can't seem to find the luck, lately.
So, my pick is 12, 31, 57, ...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
1994 GMC Topkick (A57148)
1994 GMC Topkick...
Forklift (A59228)
Forklift (A59228)
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
UNUSED FUTURE CAT305 44" EXCAVATOR RAKE (A58376)
UNUSED FUTURE...
