No back spot light
/ No back spot light #1
coupman35
Northen Ontario
Now a L4060 had B2650
Well go my b2650 tractor Monday very happy whit .Yesterday look at a few things no this there are no back spot light on it . Id like to put some on some led I see the wire are there in the back are the wire going from the front .So all I need is a switch any one have a part number for it .thanks
/ No back spot light #2
Your dealer should be able to get you the switch. Is your tractor a cab model? I know on my B2650 cab the switch is the same as the one for the front lights. I added rear lights. Wasn’t too bad. The wiring was already there.
Great thanks . Is it just a plug and go is the wire under the dash also there .And it is a cab tractor that is nice it is still cold here and am very warm in it the heat is great .
I removed the dash and found the wire and plug for the rear work lights taped up to a main part of the wiring loom . All I need now is the switch .nice
/ No back spot light #5
I bought LED's for the front and put the Kubota front lights on the rear. I don't need the rears that often. The LED's are much brighter than the halogen Kubota lights. The only kink in the plan is that trying to find matching plugs to install the LED's. I had to hard wire them in with other connectors. Works great though. Go on Messick's site and look at the exploded dash view and you can get the switch number.
Joe
Hum I looked for it but cant fin that exploded dash view
Got it Kubota: SWITCH,WORK LIGH, Part # TD350-75360
If anyone looking for the back light plugs , I found this on amazon and the work good Metra 72-4568 Speaker Harness for Select GM Vehicles only 7.00$
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
John Deere Mirrors and Light Kits (A63116)
John Deere Mirrors...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A61165)
2000 Volvo VNL...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
