BillG_in_TX
Veteran Member
Help!
I got down to the in-laws to pick up the tractor and head up to the ridge, and found that the rubber pipe on the hydraulic line just behinfd the filter had split and all the hydraulic fluid had run out. Replaced the line and refilled the reservoir with 6 gals of fluid. No action on the 3ph!
My service manual (published by Jensales) says in the capacities section that the tractor takes 5.8 gallons of transmission fluid. In the service section it says that it takes 31.7 quarts (8 gals)! Since the 3ph wasn't working, we added another 2 gals, but no change.
Another point to note is that the lift lever seems to have very little resistance. Are we missing something? Is there a line we need to bleed or a valve that needs to be opened?
Any help will be greatly appreciated.
