no 3 point
   / no 3 point #1
jimandapril97
We have a dongfeng/field pro 354 and the 3 pt hydraulics quit working. The pump still works the loader bucket. Any ideas? Is there some kind of safety cutoff that could have been triggered? Jim
   / no 3 point #2
Since no body else is answering, I'll give it a shot.
You might get better info by posting in the chinese tractor forum.
I've never seen a dongfeng, but I do have a Kama TS254. The Kama and all of the other chinese tractors that I have seen use a self contained 3pt hitch lift box with an internal valve and cylinder. There is ussually a knob that controls the drop rate of the 3pt hitch, and a bolt on the side of the lift box that diverts the fluid flow from the lift box to a remote. If your tractor has these that is where I would start. Either one too tight will cause the 3pt to stop working.
On my Kama I had a problem with the 3pt not working. My problem was caused by an O-ring blowing out in the control valve. I found the problem by taking the cover off of the lift box, and starting the tractor. No matter where I positioned the 3pt lever, oil was running out of the control valve. It was a fairly easy repair, once I found the problem.
Stan
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
Adams Tender / Magnolia Trailer (A53472)
Adams Tender /...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
