Nitrogen in auto or truck tires
   / Nitrogen in auto or truck tires #1
Bedlam
Veteran Member
OK< Know Im getting old, but try to keep up on things, Does anyone know what this new idea is about and what the advantages are? They fill the tires with nitrogen instead of air.
I noticed that the tire house had to have a sign and a revolving green light rotating in the entrance , when they are filling them.
Allan
   / Nitrogen in auto or truck tires #2
</font><font color="blue" class="small">( OK< Know Im getting old, but try to keep up on things, Does anyone know what this new idea is about and what the advantages are? They fill the tires with nitrogen instead of air.
Allan
)</font>
$$$$$$$$$ /forums/images/graemlins/grin.gif
Actually it does retain a more consistent pressure than regular air. I believe allot of this Nitrogen sales have been brought on by a certain Firestone issue.. The question would be: is it worth the trouble for the average Joe? I dont think so.. Just check your pressures on a regular basis like we have always been advised, and you should be just fine.
   / Nitrogen in auto or truck tires #3
Two things come to mind. This is merely a highly hyped gimmick to try to get an extra $19.95 per set of tires. Secondly, the light is proably a marketing ploy to get everyone within 150' to go look at the machine and potentially become a customer (sucker). If the flashing green light were any type of "real" danger light, I certainly would not want that level of dangerous material in my tires at high pressure subject to sudden blowout. I have never seen any mandatory flasing lights at welding shops, dive shops or hospitals. If compressed nitrogen is truly that dangerous, then give me plain old air at 30PSI
   / Nitrogen in auto or truck tires #5
Allan, just last week, my next door neighbor was telling me he was considering putting nitrogen in his car tires. He's a pilot for American Eagle and said that's what they have in the airplane tires because they hold the correct pressure longer and tires last longer. It's something new to me.
   / Nitrogen in auto or truck tires #6
When I was in the HVAC field we used to get replacement compressors from the manufacturers that had a holding shot of nitrogen in them to keep then dry and clean until they were installed. I think a bit of this also carries over to automobile tires as well. Plus the extra $$$$$ of course.
   / Nitrogen in auto or truck tires #7
Alot of poop about nothing. Race cars use nitrogen in the tires because it does not change pressure as much with temperature fluxuations. We are talking about a 1/4 or 1/2 pound making a big difference in a race cars handling. It means nothing to the average street driven car or truck. As far as the tire lasting longer, I don't remember wearing any out from the inside, just check your pressure when you check your oil, and you won't have a problem unless there is a leak (which nitrogen wouldn't help anyhow). U V light will do more damage in less time to the rubber from the outside. ......................................Just plain old air for me thanks! (I make it myself in my garage,,,,heheh /forums/images/graemlins/grin.gif
   / Nitrogen in auto or truck tires #8
I use nitrogen in commercial airliners everyday. The reason you use nitrogen vs compressed air is because the nitrogen has no moisture. Hence at 37,000 ft when the outside air temperature is negative 60 degrees any moisture becomes ice. So a nice big 10 pound chunk of ice inside a aircraft wheel /tire assembly at 100 plus miles per hour on landing can do allot of damage.
   / Nitrogen in auto or truck tires #9
Alan, When I was in the service (Navy) we put Nitrogen in our aircraft tires mainly because it was the only portable source where we could inflate the tires (on the plane) to 210# Nitrogen bottles typically come filled to 2100#. actually nitrogen is nothing more than really,really really dry air.and I believe the regular Joe driving now days won't see any difference in use with or without nitrogen,(except of course in his wallet!) : /forums/images/graemlins/ooo.gif
   / Nitrogen in auto or truck tires #10
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
Year: 2009 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A55788)
Year: 2009 Make...
New Swict 66" Skidloader Bucket (A50775)
New Swict 66"...
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
