Nimco part numbers
/ Nimco part numbers #1
jhwentworth
Loudon, New Hampshire
Agco ST35
I have a leaking o-ring on a Nimco control valve for my Agco ST35 with SL46 FEL. The oil leaks from the joystick base plate when the bucket is curled. The AGCO parts books lists a couple Nimco controls as being used on the SL46: the CV-112, CV-422, and CV-432. MY valve has a plate with the number 2S-40272 and a serial #219029. The base of the valve has 1M-4132-2 stamped in it.
Question: How do I interchange the numbers I have to a Nimco assembly number in the CV-XXX format.
Not exactly. Some of the valves listed on the Agco book, like CV-422, are not listed here.I'm looking for an interchange list that will convert the numbers on the tag to the numbers used on the Nimco site. I gotta tell you, this labeling stinks.
Update: I spoke with Nimco and was told that my valve was in the CV-422 family and 2S-40272 was the Nimco part number, The Nimco rep also said that the part number/family interchange information was not posted on the Internet. It figures that the Nimco valve family missing from the Nimco web site would be the valve that I have.
After taking the valve assembly apart I discovered other things wrong, so I asked my local tractor dealer for a price for a complete replacement unit. The part number is 71515225, and the quote was for $1362. Some checking around yielded a price of $586.50 + shipping. It does seem there's considerable difference in pricing, so check with the Nimco distributors.
I'll still probably go for a repair, but it helps to know that a replacement won't cost over $1300.
/ Nimco part numbers #8
after doing some research I found this out.
I used a caliper to measure the female ports
The side ports are 13/16.
The bottom 4 ports are 11/16.
so from googling around:
-08 SAE #8 3/4-16 3/4" (0.75) 11/16" (0.69)
-10 SAE #10 7/8-14 7/8" (0.88) 13/16" (0.81)
So for us to get the valve we would need a sae male #8 to sae female#10 adapter? for the side ports?? Like the following?
http://www.surpluscenter.com/item.asp?item=9-6410-8-10&catname=hydraulic
All of the line threads have O rings.
/ Nimco part numbers #9
Sounds like you have it figured out TJ.
/ Nimco part numbers #10
Sounds good. I ordered up all the parts 230 bucks.
So I will post for everyone else on how I make out.
I was not spending $1400 at massey dealer for another nimco valve.
/ Nimco part numbers #11
/ Nimco part numbers #12
Your welcome TJ, I am glad it all worked out for you. For others in the future-can you take pictures and list any adapters you needed?
/ Nimco part numbers #13
you need a seal kit of a part number # 4s-40320 Agco # 71512160
if Agco doesn't help you can go through IFP - 763-252-1181
/ Nimco part numbers #14
I hate people that spam!
/ Nimco part numbers #15
Hey guys, after mowing for a few hours today, I noticed that the valve is hot! I can touch it but it seems too warm for comfort.
Is it because I put the adapters on the valve? sae 10 to sae 8 to fit the new valve???
I know the valve is set at 2000 relief pressure do I need to change that? and if so how do I?
Any help would be appreciated.
Thanks
/ Nimco part numbers #16
I have the same problem with the Nimco valve 2S-40272. I am a new member and I sure do need some help. I understand that the 9-7401 control valve from surplus center will work as a replacement for the 2S-40272 valve. I am not sure about the adapters for the hoses to connect to the 9-7401 valve.
I am asking anyone to please advise me on this. Thanks
/ Nimco part numbers #17
JJ, My name is wpettit, would you please look at my post from yesterday about the control valve on my 1246 MF loader and email me a answer. I am knew to this and
am not sure how to navigate. thanks,eddie
/ Nimco part numbers #18
This is the valve you posted. The ports are SAE-8
https://www.surpluscenter.com/item.asp?catname=hydraulic&qty=1&item=9-7401
When you order, just tell them what you have now, and they will send the valve with the fittings, or order only the valve, and go to your local hyd shop and they will help you set up the valve with the correct adapters.
You need to be able to ID the hose ends you have now, JIC, NPT, etc.size.
Look through this site, and you will educate yourself
http://www.discounthydraulichose.com/
http://www.discounthydraulichose.com/category_s/55.htm
/ Nimco part numbers #19
JJ, Thanks for the info on the valve. Eddie
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
QA Mini Plate (A64912)
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
COMBO PORTAPOTTY/TRASH TRAILER (A67714)
COMBO...
