Nice rear end
   / Nice rear end #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
I was at large ag dealer the other day that happened to carry Kubota and used to carry Kioti. I noticed he had an L39xx, a consideration of mine in hindsight as I'd owned both a Kubota lawn tractor and a BX series sub-compact in the past. I had to take a closer look to compare to my CT235. I must say I wasn't overly impressed with the cab layout but it wasn't until I looked at the 3PH that I realized how scrawny it looked. For a tractor near 40hp it's lower support arms must be half the thickness of the CT, attached to immensely inconvenient turnbuckles for sway control (I'm constantly switching implements from FM, BB, Spryr, lawn rake and I need the convenience of pulling a chain linked pin out of nestled square tubes to control the span among with, oh yeah, extendable link ends. It didn't have those either. Nor the manually operated extendable cylinder on one side to control tilt. It simply looked so naked and scrawny that had the scenario been reversed and I was looking at the rear end of a CT 5hp less than a Kubota I'd invested in, I'd have been really disappointed. Not to mention the seat on the CT, of which there is no comparison. I think the caveat was that when I mentioned to the chap from the dealership that was helping me load a Claas Jaguar Forrager some of my observations, he mentioned that they were carrying Kioti before and that in many ways the Kioti had superior characteristics.
So stay thirsty my friends. The hot summer is only begun!
   / Nice rear end #2
"And then the fight began"
   / Nice rear end #3
Or, does this Kubota make my rear end look bigger"
   / Nice rear end #4
:D
Actually I believe Kubota uses high strength steel in their lower arms and any good dealer worth beans will swap out the turn buckles to their quick set up system similar to what we have. Next time your in ask.
   / Nice rear end #5
It sounds like you like yours with more junk in the trunk.
   / Nice rear end
Hmmm....1433lbs at 24" and the CT is 1764lbs at 24". The Kubota weighs between 2590lbs and 2778lbs and the CT weighs 3055lbs. Looks pretty good to me😁
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
Pallet Fees (A50775)
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
