NH1925 Battery
   / NH1925 Battery #11
Mike, I don't see anything wrong with a gel-cell if they have the cranking amps required for a diesel engine. Our engines are pretty small compared to the one in my Dodge 3/4 ton(Cummins), but my Dodge has two batteries. I haven't done any research, so be sure and tell us what you find out.
JimI
   / NH1925 Battery #12
Duane, besides not having a battery box like a boat (which I think would be justified, but I'm not in NH engineering) I think the location of the Boomer batteries is significant. On my Ford Jubilee, the battery is between the engine and the steering column, so it doesn't get "thrashed" around quite like being directly above the front axle. I love the location of the battery for ease of access, but it sure gets jostled a lot.
JimI
   / NH1925 Battery #13
I agree, but the available sizes are too big (bigger than 24 which was what boomerbrent had mentioned). So I went searching for something similar and found the Lifeline batteries.
   / NH1925 Battery #14
Thanks for the link, Mike. You can be sure that if I continue to have problems controlling battery leakage, I'll first try to fabricate a battery box or go with one of these sealed gel-cels no matter how much they cost./w3tcompact/icons/shocked.gif
JimI
   / NH1925 Battery #15
Jim, would one of those marine-type plastic battery boxes work? Here in Michigan they're only $10 bucks. Since they're a little larger than the battery, I'm not sure they'd fit, but would save you a lot of fabrication time.
   / NH1925 Battery #16
We used one of the plastic battery boxes when we converted our 1973 MGB from two six volt batteries behind the seats to one 12 volt battery in the trunk. Worked great.
   / NH1925 Battery #17
Duane and Mike, I'm a big fan of those battery boxes and that's the first thing I thought of , but the battery mounting clips fit onto lips on the sides of the battery. I don't think there is enough room for a box. However, If I used a nylon strap that often comes with those boxes to stap the box down to the battery shelf, I might not need the side clips. I'm going to do some engine temperature gage troubleshooting today (Yep, I'm still working on that, Duane) and I'll check the clearance I have around the battery. I'm sure I have enough vertical clearance, just don't know about side-to-side.
JimI
   / NH1925 Battery #18
We used the nylon strap in our MGB. Never had a problem with it.
   / NH1925 Battery #19
<font color=blue>...We used the nylon strap in our MGB...</font color=blue>
Out in So. Cal, I had a great little MGB-GT, can't remember the year...60's something, and a $20-25. full deluxe Tijuana paint job... and that included painting the carpets and dash.../w3tcompact/icons/blush.gif
Anyhow... in what year did you own your MGB... cause I thought the nylon tow straps were only the past 10/15 years?
   / NH1925 Battery #20
We had a 1974 MGB that was actually made in late 1973. It was one of the last ones with the chrome bumpers instead of the big rubber ones.
We sold it in the mid-80s so we would have converted it to the 12v battery, with the battery box and nylon hold down strap, about that time.
kids dirt bike (A56859)
kids dirt bike...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
NEW Fork Extensions (A59000)
NEW Fork...
