NH Wheel Weights .
   / NH Wheel Weights . #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
The manual States only use 2 weights per wheel , each weight weighing 107 lbs.
I see that PineRidge has put 3 weights on each wheel. New Holland only wants 2 weights per wheel, to reduce Stress on the Wheel/Axle Bearings.
Question to PineRidge,
Are the 3 weights on each wheel ALL the time?
If so, How long have you run the Weights ?
Have you noticed any problems from the Extra Weight?
I would think that an extra 100 lbs on each wheel , would be a lot less stress than a 900 lb weight bar on the 3PH along with the Weight of the Tractor.
Thanks
   / NH Wheel Weights . #2
The dealer set the tractor up with 3 wheel weights on each side and the 3 point weight rack. However I really don't think these weights are much more than 80 pounds each, either that or I'm getting stronger moving them around. :D
The wheel weights are mounted 90% of the time, and have been on since the tractor was new in 2003. Haven't had any axle problems yet.
   / NH Wheel Weights . #3
I have question for PineRidge about adding wheel weights to a NH tractor. I believe you had a link to a picture or picture of something that was put on a floor jack to lift and position them so they could be bolted on the wheels. Is that correct? I would appreciate if you could provide that link or info since I can't find it now.
I would like to put a set on weights on each of the rear wheels on a TC-45D.
Thanks.
   / NH Wheel Weights . #4
This is a standard floor jack. The lift pad was removed (simply lifted off) and the welded solid steel rod substituted. It makes easy work of installing/removing weights and the floor jack will revert back to stock as well.
   / NH Wheel Weights . #5
Mike,
I miss your Web site with all your projects. It was a reference point for me. Any chance of bringing it back?
   / NH Wheel Weights . #6
Barry I'm not sure why the material was deleted unless there was some problem with the sever itself. Guess that's a problem when you don't host your own material.
When I get a bit more time from my contractor job the material will be re-posted.
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
International Harvester Farmall FC (A50514)
International...
2007 Polaris Ranger (A50514)
2007 Polaris...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
1995 1063 Corn Head (A50514)
1995 1063 Corn...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
