nh tz25da
   / nh tz25da #1
gbscomp
new holland tz25da
hi
hoping someone can give me some guidance.
tractor will not start seems to be grounding out or starter issues. The lights work and glow plug but as soon as I turn to start it clicks and goes dead. Have to remove the cables from the battery and it will reset itself. Have checked the fuses and they look ok. Checked the battery and its measuring over 12 volts. starter or solenoid ? where is the solenoid located ? I am a newbie when it comes to working on tractors. thanks for the help
   / nh tz25da #2
Have you checked the battery under load? You can have 12v but as soon as you try to turn the starter, the voltage will drop out.
2019 Kubota SVL75-2 (A53317)
2019 Kubota...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A57024)
2002 Chevrolet...
VERMEER D9X13 SERIES II HORIZONTAL DRILL (A52707)
VERMEER D9X13...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
LaneShark LS3 (A56469)
