Mowing NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?....
   / NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?.... #1
gooffer69
Kingston, NY
TZ18DA, TC45DA
Anyone tried this ? I have my doubts if it's possible.... my 54 CMS deck goes thru front wheels like it's going out of style... I know grease and adjustment but the construction totally sucks, the 914a deck the front wheel can pivot the 54/60 CMS decks are fixed hence you wear out front wheels like crazy...
Anyone ! advice please ... other thought is to MOD the 54 CMS deck with custom wheels so it stops breaking expensive wheels 24/7 !
wow almost 30 days and nobody has a nice solution... must not be many of those TZ18's out there....
   / NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?.... #3
Don't let your deck ride on the wheels?
it rides on it's wheels except they don't swivel hence they were out super fast.
   / NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?.... #5
The deck shouldn't ride on the wheels. The wheels should be adjusted to about 3/8" off the ground only touching when needing to keep the deck from scalping.
I had a TZ25Da (same as TZ18) with 500 hours on the factory wheels on its 60cms deck. Keep the wheels off the ground and they will last much longer.
why should the deck ride on it's wheels ??? that makes very little sense that would mean your cut is never the right height
   / NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?.... #7
deck should NOT ride on wheels
And how on earth will you get an even cut unless you have a lawn that is perfectly flat ????
   / NH TZ18DA 54 CMS ... upgrade to TC18 914a deck ?.... #9
Get an owners manual for your deck and read it, all explained there. People are trying to help and you won't budge.:eek:
Edit:
PsRumors has it right, set your cutting height with the adjustment knob and then set your wheels approx 1/2 inch up from the ground. The wheels are only there to prevent the deck from gouging on uneven ground. If none of this makes sense, the manual will probably have pictures.
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
2010 International 7600 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2010 International...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
