NH TT60 Fuel Problem
/ NH TT60 Fuel Problem #1
Paul1952
Can anyone tell me where the allen head drain plug is located on the fuel tank. I think I have trash in the tank, but I can't locate this thing to drain it. I figured it might be around the sump area, but unless I'm overlooking it, I can't find it. Thanks.
/ NH TT60 Fuel Problem #2
The parts book doesn't show a plug of any type, only the outlet fitting. I don't think you could access a drain plug without removing the tank. If you are having fuel supply problems have you been through the inlet banjo bolt and fitting/ primer pump suction screen? My experience with TT series plastic tanks has been fragments of tank material caught in the fitting and the screen in the supply pump to be very common untill all the machinework debris is finally flushed from the tank.
I called my dealer and the shop guy told me about the allen head plug, but I can't find anything like it, so maybe that's why, its not there. Harry, I haven't tried that but will.....I keep changing fuel filters, works for a while, but can't keep doing that either.
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
4022CFL (A59228)
4022CFL (A59228)
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
