NH-TNA vs CASE-JXC
   / NH-TNA vs CASE-JXC #1
BER
SW. Indiana
MF1235 HST MFWD
I've been looking around on the manufacturers web sites, and noticed some simularties between the NH-TN60A and the CASE-JX1060C machines. Would anyone know if the two machines are related?
   / NH-TNA vs CASE-JXC #2
They are virtually the same. They are made by the Case NewHolland Co. a recent merger of the 2 companies makes it so there is little difference between the Case and NewHolland tractors
Thanks for the info. The NH site gives more detailed spec sheets on the TN60A. I have to assume the JX1060C specs would be close, for turn radius, ground clearance, length, etc. How do the two compare price wise?
   / NH-TNA vs CASE-JXC #4
They should be close enough that pricing them from potential selling dealers is the best way for you to get a meaningful answer. Be sure to compare like units; there are many options and configurations. If you want/need SuperSteer, only NH has it.
   / NH-TNA vs CASE-JXC #5
Check out the Case JX series as well. They are less money and have good or better specs (higher 3pt hitch rating) than the JXC series. There are more engine choices in the JX series too.
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
